aracid Posted January 30, 2006 Share Posted January 30, 2006 hey all i wonder if it would be possible to render lights ie, key light, fill light, and back light, and kicker light, all in their own channel, with one renderpass - much like an object id render pass. i know one can light the scene with the RGB lighting setup(to relight the shot in comps), but i'm thinking of using more than the standard 3 point setup and rather export some sort of light id pass inwhich i can modify the intensities of every channel. thus relight the scene with unlimited lights. i hope im making myself clear but does anyone know how to do this ? thanks in advance aracid Quote Link to comment Share on other sites More sharing options...
doc Posted January 30, 2006 Share Posted January 30, 2006 I believe you can do this by exporting attributes from your lights to your surface shader, calculate the lighting, then export those values from the surface shader. Have a look at the limport() vex function or "Import Light Variable VOP" if you prefer using the VOPs. note: these functions are only avaiable in an illuminace loop. let me know if you have any questions. Luca Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted January 31, 2006 Share Posted January 31, 2006 Here's one approach that will do it without requiring your lights to export anything. This little test shader can accommodate up to 3 lights, which it splits into diffuse and specular: #pragma hint DiffTint color #pragma hint SpecTint color #pragma hint l1_diff hidden #pragma hint l1_spec hidden #pragma hint l2_diff hidden #pragma hint l2_spec hidden #pragma hint l3_diff hidden #pragma hint l3_spec hidden surface testLightExport( //Reflectance vector DiffTint = 1; float DiffAmp = 0.8; float DiffRough = 0; vector SpecTint = 1; float SpecAmp = 0.2; float SpecRough = 0.05; //Light separation string l1_name = ""; string l2_name = ""; string l3_name = ""; export vector l1_diff = 0; export vector l1_spec = 0; export vector l2_diff = 0; export vector l2_spec = 0; export vector l3_diff = 0; export vector l3_spec = 0; ) { vector Nf = normalize(frontface(N,I)); vector V = normalize(-I); vector diff = 0, spec = 0; illuminance(P,Nf) { shadow(Cl); vector Ln = normalize(L); vector cd = Cl*DiffTint*DiffAmp*diffuseBRDF(Ln,Nf,V,DiffRough); vector cs = Cl*SpecTint*SpecAmp*specularBRDF(Ln,Nf,V,SpecRough); string lname = getlightname(); if(lname==l1_name) { l1_diff = cd; l1_spec = cs; } else if(lname==l2_name) { l2_diff = cd; l2_spec = cs; } else if(lname==l3_name) { l3_diff = cd; l3_spec = cs; } diff += cd; spec += cs; } Cf = diff+spec; } And here's a test hip that uses it (just render the "MANTRA" ROP): testLightSplits.zip Yup. It's awkward. It's a bit of a pain... but at least it can be done. Let's keep our fingers crossed that this kind of thing will be made easier in H9 Cheers! Quote Link to comment Share on other sites More sharing options...
aracid Posted January 31, 2006 Author Share Posted January 31, 2006 hey guys thanks for the reply and info, i will definately take a look at this :-) all the best Quote Link to comment Share on other sites More sharing options...
sibarrick Posted January 31, 2006 Share Posted January 31, 2006 The way things are going with deep rasters and ipr do you think the two will merge? Essentially the render process won't create a final image at all it will simply herd all the information into some sort of uber format, halo will then read it in and you could re-light re-texture change shadows everything except change the model....... Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted January 31, 2006 Share Posted January 31, 2006 The way things are going with deep rasters and ipr do you think the two will merge? Essentially the render process won't create a final image at all it will simply herd all the information into some sort of uber format, halo will then read it in and you could re-light re-texture change shadows everything except change the model....... 24294[/snapback] Yes, I think you're right. We're using layers more and more these days, and realizing that it's too much of a time-saver (in terms of both client tweaking and "look exploration") to ignore. Although it also means making some deep changes in "the way things are done" (shading libraries, etc.)... but that's just growing pains. When you read Pixar's "Lpics" paper, you realize that, at the heart of it, it's really a bunch of these layers (granted, with a lot of non-trivial caching and hardware-assisted-what-not thrown in)... so I agree that in maybe the not-so-distant future we'll be doing all the combinatorial/compositing aspects of shading (plus lighting and reflectance maybe) in Halo (?). Bye bye monolithic renders. The times, they are a-changing... Quote Link to comment Share on other sites More sharing options...
