Interpolating Between Curves
keltuzar
I am in the process of writing a dso that will generate hairs.
I am using Maya and Slim to implement it.
I have hit a brick wall when it comes to interpolating between curves.
Here is an image of the idea...
So far what I have is very simple where the dso creates curves off the normal at the surface point. What I really want to achieve is a way to interpolate between hair as guides. Problem is that for every new cv I create I have to weight it with the location of the cvs of the guides to determine where it must be positioned.
Here is another image of what I want to do, to break it down how can one go abouut creating the dotted lined curves in such a way that it interpolates between two curves. Also if this can be solved I can then get a way for more than 2.....
If anyone have any suggestions please help.
thanks
