JH12 Posted April 19, 2018 Share Posted April 19, 2018 (edited) Hi, I'm using redshift to render a camera moving through some clouds (static). The clouds are imported with a File node, as they were previously cooked out to disk. The volume is a reasonable resolution (vdbs are around 300mb each and Im loading 2 of them). I import the clouds with separate File nodes, and render using one RS light. The render itself is fast but at the start of every frame, it goes through a "extracting object/...filepath.vdb" process which lasts for > 10 minutes per frame before each frame renders. What is happening here and is there a way I can reduce this time? Also tried loading .bgeos and have the same problem. Cheers for any advice Edited April 19, 2018 by Fireandsmoke Quote Link to comment Share on other sites More sharing options...
