Controlling shader properties
trandzik
Hello,
I am trying to set value of shop_disable_displace_shader parameter using Properties VOP inside material. Setting its value manually works without problem, but when I plug some value in this parameter, it won't update anymore. I have created simple setup, where disable_disp attribute from geometry is used as value for shop_disable_displace_shader. Unfortunately, changing disable_disp won't change the state of shop_disable_displace_shader. Same value is set as color, so I am sure Bind VOP inside material is working. Please, does anyone know what is wrong with this setup or how can I make it work? Thanks.
Peter
properties.hiplc
As far as I understand, shader properties are evaluated as a whole, for the shader, so plugging attributes that are being calculated as the rays are being fired won´t work there.
To make that work, like, if you need to disable displacement for objects that are far from the camera, you will need to use material stylesheets. Look for the first part of the stylesheet webinar with Jeff Wagner, he teaches how to do that!
