RickWork Posted March 12, 2006 Share Posted March 12, 2006 Hello, I'm trying to set an object's min&max bounds under the render tab to reference an attribute that I create inside the sop network. Right now I'm using opparm echo "getting bounds file now for $object" # /----------------------------------------- # Min Bounds set xmin = `bbox($outName, D_XMIN)` set ymin = `bbox($outName, D_YMIN)` set zmin = `bbox($outName, D_ZMIN)` # Max Bounds set xmax = `bbox($outName, D_XMAX)` set ymax = `bbox($outName, D_YMAX)` set zmax = `bbox($outName, D_ZMAX)` # Now set the bounds and archive source echo "setting bounds for $object" # /------------------------------------- # We should really use ch refs as the geo might # be deforming and/or changing size per frame! # Min Bounds opparm -C `oppwf()` detail_minx $xmin opparm -C `oppwf()` detail_miny $ymin opparm -C `oppwf()` detail_minz $zmin # Max Bounds opparm -C `oppwf()` detail_maxx $xmax opparm -C `oppwf()` detail_maxy $ymax opparm -C `oppwf()` detail_maxz $zmax While the above works ok, I don't think this will work if the object is scaling or deforming drastically in sops. I was thinking of creating 2 attribute sops, 1 for min and 1 for max. I would channel reference these sops so that the values for the File min/max bounds would update per frame. The problem is, I can't opparm a channel reference. I also tried chsraw, but that didn't work. A quick search on here turned up with a post using chkey but I don't want to key my channel reference. Cheers, /Rick Quote Link to comment Share on other sites More sharing options...
sibarrick Posted March 12, 2006 Share Posted March 12, 2006 To do this so it updates with any changes you need to put your bbox expression straight into the parameter. To do that you need to add a channel. So the answer is yes you will need chkey. The easiest thing to do in these situations is to put the expression in manually once then use opscript on the node to see what hscript commands you need to recreate it. Quote Link to comment Share on other sites More sharing options...
RickWork Posted March 12, 2006 Author Share Posted March 12, 2006 To do this so it updates with any changes you need to put your bbox expression straight into the parameter. To do that you need to add a channel. So the answer is yes you will need chkey.The easiest thing to do in these situations is to put the expression in manually once then use opscript on the node to see what hscript commands you need to recreate it. 25578[/snapback] very cool. I forgot that houdini will output the hscript command in opscript. Thanks! Quote Link to comment Share on other sites More sharing options...
RickWork Posted March 12, 2006 Author Share Posted March 12, 2006 Sure does work now but looks a bit sloppy.. # /----------------------------------------- # Min Bounds # /----------------------------------------- chadd -t 0 0 $object detail_minx chkey -t 0 -v -1 -m 0 -A 0 -F "bbox(\"$object/$outName\", D_XMIN)" $object/detail_minx chadd -t 0 0 $object detail_miny chkey -t 0 -v -1 -m 0 -A 0 -F "bbox(\"$object/$outName\", D_YMIN)" $object/detail_miny chadd -t 0 0 $object detail_minz chkey -t 0 -v -1 -m 0 -A 0 -F "bbox(\"$object/$outName\", D_ZMIN)" $object/detail_minz # /----------------------------------------- # Max Bounds # /----------------------------------------- chadd -t 0 0 $object detail_maxx chkey -t 0 -v -1 -m 0 -A 0 -F "bbox(\"$object/$outName\", D_XMAX)" $object/detail_maxx chadd -t 0 0 $object detail_maxy chkey -t 0 -v -1 -m 0 -A 0 -F "bbox(\"$object/$outName\", D_YMAX)" $object/detail_maxy chadd -t 0 0 $object detail_maxz chkey -t 0 -v -1 -m 0 -A 0 -F "bbox(\"$object/$outName\", D_ZMAX)" $object/detail_maxz Thanks Quote Link to comment Share on other sites More sharing options...
