nm8r Posted March 28, 2006 Share Posted March 28, 2006 I added a spare param to a node using opspare with the -r flag setting the range from 0 to 1. I'd like to change the range now. I suppose I could delete the param and add it again with a different range, but that seems kinda lame. Is there a way I can just edit the range? Using opspare without the -a or -d flags doesnt seem to work. Along the same lines, this range appears to be soft. Is there a way to make the range hard (so that it's enforced even when typing in values)? thx Quote Link to comment Share on other sites More sharing options...
