feresteanud Posted May 11, 2018 Share Posted May 11, 2018 Hello, I was just wondering where the small jittering is comming from in flip fluids. It is obvious aftering meshing it. I found kind of a solution, in point vop, if veloctiy is smaller than a value then flatten on y axis, but it is not ok in all in some cases. Did some of you encounter something similar? Can this be avoided? Thank you. Quote Link to comment Share on other sites More sharing options...
