Fluid Stream affecting Piece of Cloth _ Fluid Force Issues (SOLVED)
Justin K
Hello!--im trying to get a piece of cloth to interact with a fluid sim.   I think I am supposed to use the fluidforce dop for this.  Im using the examples in help as reference.  The examples however are only for wire set ups not cloth--though they say for cloth as well.  When I try and use the setups (with the needed tweaks for cloth) there is no real interactivity.  If I reorder them and put the cloth first the fluid recognizes the cloth as a collision object, but doesnt affect it.  The other way around I get nothing.   As far as I can tell from the wire setups, the fluid needs to be sourced first anyway.   Im trying some alternative approaches with sop solvers and not--but the results are pretty awful lol.
Any suggestions?
Thanks!
FLUID_CLOTH_TEST_v004.hiplcFetching info...
Edited by Justin K
