OpenGL ROP, Wire (edge) render, Antialiasing
Please, did you manage to render the wires (edges) with anti-aliasing with OpenGL ROP? Polygons get anti-aliased fine, so I could PolyWire the wires, but that slows down the render.
Thank you very much! I have discovered, that the problem appears, when I enable these two things at the same time:
- enable High Quality Lighting on the OpenGL ROP
- enable any light in the scene
Then the wires (open polygons) are not antialiased. Closed still render antialiased, fine. I will investigate some more. Thank you very very much, I can do my render now.
