dvelasco Posted June 5, 2018 Share Posted June 5, 2018 Hello! I am new to Houdini, but am attempting a fairly complex effect. I need to emit smoke and particles from a piece of geometry, with these specific characteristics: The smoke and the particles must start off as grey. The particles should be emmited from a black-and-white mask that is mapped onto the emmiting surface (white=emit, black=no particles emmited). This texture should be animated. The color of the particles should be defined at particle birth by another moving texture (an animated fractal noise, for example). At 1/3 of their lifespan, the smoke and the particles would change into two different colors (blue and pink,. I am guessing that the right way to do this is to start with the particles, and then copy the color attributes onto the smoke. The two should move together, so... should I first do the smoke, and them move the particles along the same forces? Any help would be greatly appreciated! cheers, Diego Quote Link to comment Share on other sites More sharing options...
