breaking glue and hard constraints;
Instead of changing the constraint name, you could just put it in the broken group, and append a dlete node after your Wrangle, setup to delete primitives that belong to broken group.
So just replace the line s@constraint_name = "pin_broken"; by @group_broken = 1;
and append a delete node with the group mask with "broken" inside.
