controlling sequence with CHOPs
lugnut
I'm doing a simple "flicker" animation where I use a COP blend node with the factor param controlled by CHOPs to turn frames on and off. I can render to a flipbook, but the composite ROP just gives me black frames? Anybody know why this happens and if there is a workaround ( besides saving from mplay)?
BTW the replacing the blend with a switch COP dosen't work at all, I'm assuming because the switch is not cooking the input, is that correct?
Thanks for any info
