auto enable switch for static solver in dopnet
UpyopyoSky
Hi, I try to make my default set up. Then I want to make a auto-enable setting for staticObject node, instead of creating/deleting the node every time. This is because whitewater solver, for instance, makes a strange collision artifact if staticObject node does not get any collision objects from SOP. So far, I tried a enableSolver, switch node with  if(nprims(surface)>0, 0, 1), etc. None of them works well. Alternatively I made to insert a dummy object in SOP, then the staticObject takes it to avoid artifact. We could unlock the staticObject node and implement nodes in there, but I want to avoid this way because it causes a file size larger.
Does anyone have smart ideas to do auto-enable/bypass staticObject node?
Edited by tagosaku
