khedkarsanto Posted June 23, 2018 Share Posted June 23, 2018 (edited) ..Does anyone has idea to control slip field over the age of same flip particles, I want tocontrolslip over the age of viscus fluid. Particles should not be moving at all initially and over the age it will start moving. Thank You I have tried with gas match field and gas-field vop, it works perfectly when you fetch volume data from sop and export slip, but I want to the same effect with the particle age. I am not sure is this the way to achieve this but may be converting particle particle age in to a custom field which I can refer as a reference field and It might work. If anyone has any idea please let me know. Thank YOu. Edited June 23, 2018 by khedkarsanto Quote Link to comment Share on other sites More sharing options...
