Caching Data between cooks
Hello out there,
I've been taking a good hard look at the SOP_NodeVerb API, and was wondering whether anyone had any pointers on best practices for calling certain functions only when the input geometry has changed. In my case this building a GEO_PointTree and a GEO_DetachedHedgeInterface, the result of which I've been storing in the subclassed SOP_NodeCache.
I managed to get something working using COOK_GENERIC and DEP_MicroNode to check when the input node had last been visited to decide whether or not to run cookInputs() and update the cache. But it feels hacky and horrible :unsure:
There's a strong possibility that I've over-complicated things here, and just wanted to reach out in case anyone had any 'patterns' to hand for this before I go down any other blind alleys
Cheers!
Henry
Does the SOP_WindingNumber sample not show what your looking for?
A GU_Detail is a collection of attributes(like a position attribute but also for topology) so when your asking if a geometry has changed, your really asking what attributes in the GU_Detail have changed.  All attributes are tracked with GA_DataId, so caching the data id of the attribute you're interested in and checking that against the incoming geometry will allow you to check for any relevant changes.  The SOP_WindingNumberCache::update3D function in particular seems to show a way to do what your describing.
