evanrudefx Posted July 18, 2018 Share Posted July 18, 2018 What is the purpose of the VDB sop? The only time I have seen it used is with volume rasterize particles when creating white water. What other times would you use it? Also, what is the point of the visualization? The documentation says the node is creating empty vdb's so what is there to visualize? Also, I can't get it to actually show anything other than the bounding box showing the voxel size. thanks in advance. Quote Link to comment Share on other sites More sharing options...
