Pancho Posted August 21, 2018 Share Posted August 21, 2018 I need to retime a cached simulation. So far no problem if I do have a constant playback speed. The way I interpolate the cache should be able to handle changing playback speeds. But here comes the problem. As the input for the retiming I want a ) the FPS and b ) the current playback speed in form of a curve. Playback speed could change to whatever value. but if the playback speed would be constant the curve would be flat (e.g. constant value of 1 if the playback speed is normal, 2 for double playback speed). Since the retiming node needs a frame value as the input I need to convert my playback speed curve into a current frame curve. But how is this possible? For the constant playback speed I just need to multiply the FPS by my speed factor. Easy. For my changing playback speed I would need to do this for every frame (current playback speed x FPS) and then add all these values together which are left of the current value in the timeline. This seems to be a rather complicated and slow thing. Especially for longer animations. I don't have an idea how to solve this practically. Is there some native functionallity hidden CHOPS to solve this? Avoided CHOPS so far completely. : / Thanks for any tip!!! Tom Quote Link to comment Share on other sites More sharing options...
