ikoon Posted August 27, 2018 Share Posted August 27, 2018 Very often, I need to select previously selected node. Usually because I go upstream and change some parameter, then I want to return back down. Or I want to compare parameters of few nodes and toggle between them. I just had two ideas how to do that: 1) bind event callback for hou.nodeEventType.ChildSelectionChanged and save my own undo history ... this works, but it is probably bad idea, because I would have to add callback for every node? 2) save selection with putenv (more than one node) and switch between those nodes ... this is fine, when I want just to compare few node's parameters Please, do you have any idea, how to do it right? Here is my script which helps me toggle selection between few nodes: def selection_switch () : nodes = hou.selectedNodes() count = len(nodes) if count > 1 : # if few nodes are selected, then initialize, save that selection selection_stack = ','.join(node.path() for node in nodes) hou.putenv('selection_stack', selection_stack ) hou.putenv('selection_current', '0' ) hou.putenv('selection_count' , str(count) ) # even if one node is selected... selection_stack = hou.getenv('selection_stack', 'none') selection_current = hou.getenv('selection_current', 'none') selection_count = hou.getenv('selection_count', 'none') # go to next node... stack = selection_stack.split(',') current = int(selection_current) + 1 count = int(selection_count) if current == count : current = 0 # update the saved variable hou.putenv('selection_current', str(current) ) # select that node in current pane target = hou.node(stack[current]) parm_pane = wf_selection.pane_linkGroup( hou.paneTabType.Parm ) parm_pane.setCurrentNode(target,True) Quote Link to comment Share on other sites More sharing options...
