Render Can't Keep Up With Script Running
MADjestic
Hi, folks
I've been scripting a bit in the eve - I've been following this tutorial with some modifications - http://cade.scope.edu/courseware/notes/houdini/script.html
and the obstacle I struck was that it seems that the script was running so fast that it didn't allow renderers and izmatte to finish their task - as a result I was getting a composited image with lots of artifacts that are characterisitc to situations when you interrupt the rendering (you see a piece of a normally rendered image and the rest of the poicture are just smudged lines, going up, or something like that). So what I did was - I added
for wait_var = 1 to 10000
echo $wait_var
end
pieces of code into the script everywhere where you can see
render my_ROP
and
izmatte
- as a result I was getting a nomral composit, though the render times got astonishingly long, obviously.
So my question is whether there is a way to make HScript wait untill every operation is complete, before contnuing to the next line of the script?
Thanks.
