johnLIC Posted September 12, 2018 Share Posted September 12, 2018 (edited) I'm caching a Pyro sim out as VDB. I want to preview my work, but when I read in the VDB, using a fileCache node, it is a mostly white blob. How can I bring in VDBs so that they display correctly for flipbooking? (They render fine) Or, is there a conversion I need to do? I'm optimistic there's a solution I'm just not familiar with.... SOLVED: volume visualization node set to read density. Edited September 12, 2018 by johnLIC Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted September 12, 2018 Share Posted September 12, 2018 I would use a volume visualization node. It has all the setting you need to visualize the different fields. Quote Link to comment Share on other sites More sharing options...
