Default Node Graphics
TheDude
I was wondering if OPscript file is no longer supported for setting desired node preferences in your network view?
I have also seen that now under Network View Display Options, under Themes tab, it now has pull downs / user made settings for shapes, colors, and wire style. This however saves a pretty gross .json, which is fine if you are not looking to edit this in the text editor (but that was the benefit of OPscript). It also appears that, unless you are going to edit the json through a text editor, you now have to make a new theme whenever you'd like to change your default settings, and this has no way of replacing your current custom theme. These are all changes I don't like D:
Is OPscript no longer supported?
