3__ Posted May 1, 2006 Share Posted May 1, 2006 another quick question: Is it possible to resample a curve with a bias? I'd like to do something like this: Draw a curve, resample with ## maximum segments, append a point sop and make Cd: sin($PT / ($NPT / 180)), 0, 0 Then resample the curve again using $CR as a bias, with more points being added where $CR is highest. scatter seems to be the most likely solution but it doesn't seem to like $CR as an attribute. -cpb Quote Link to comment Share on other sites More sharing options...
old school Posted May 2, 2006 Share Posted May 2, 2006 Tried POPs? Pass the curve in to a Source POP. In the Birth folder use Impulse activation set to $FF==1 and set your Impulse Birth Rate. For the Birth Probability try something like: $CR*0.3 $CR*1 To skew the waiting, adust the multipliers. To help rebuild the curve, I created ptnum and stuffed in $PT then used this to sort then add to rebuild curve. Hacky but not too bad. I wonder why the Distribution Attribute in the Source folder of the Source POP doesn't quite work for Edges (attribute) on curves. Perhaps it needs a surface. Quote Link to comment Share on other sites More sharing options...
3__ Posted May 16, 2006 Author Share Posted May 16, 2006 results using pops were a bit too noisy, also had trouble sorting/adding using ptnum. sometimes even with $CR when applied as $PT/$NPT... resample_curve.zipFetching info... Quote Link to comment Share on other sites More sharing options...
