Using Vellum/SOp solvers with changing geometry
caleb
Yo smartipantses!
I'm just noodling with vellum for the first time. Has anyone had success with a vellum solver integrating with a SOp solver that is changing the topology?
In particular, I want the equivalent of a wire solver, so I'm using the hair constraint template. The wires are open polygons - growing by adding new points to the end every so often. I'd like the added edges to be added with the same bend and stretch constraints that the pre-existing edges have
Can anyone point me at a solution or example hip which runs a vellum solver with a SOp solver, where the latter is adding geometry throughout the simulation?
(The image shows the first point added just falling - with ineffective constraints. I've tried several variants with essentially similar results.)
Thanks!
Edited by caleb
clarifying, and typos
  • 2 weeks later...
