Select Similar components or objects (topology or volume)
dive819
Hey OD Force,
Decided to try and use Houdini 17 with HDM as my main hard surface modeler. Coming from a highly customized Maya set up.
Is there a way to select an object, and run a "select similar" command.
For components, it would select similar faces / edges / verts if the component had some type of symeterey (such as right vs left, top vs bottom,)
For objects, it would select similar objects that have matching topology / bounding box volume.
If more than 2 objects are select it woud select all objects in the scene by type such as poly objects, nurbs, etc
I know at some point I would need to figure out a branching template for python commands, but to start, is there a select similar command?
Edited by dive819
