timj Posted November 2, 2018 Share Posted November 2, 2018 Does anyone have a solution? how can i connect the in and out group to each other without any other connections? Quote Link to comment Share on other sites More sharing options...
coltonmil Posted November 2, 2018 Share Posted November 2, 2018 Assuming the points you wish to connect have a corresponding id attribute (or something similar), you just merge the points and the Add SOP should do the trick! Set it to the "Polygons" tab, then "By Group" tab within there, set the "Add" drop down to by attribute, and enter the name of your id attribute. If you don't have an id attribute, do all of the above, and instead set "Add" to groups of N points. Quote Link to comment Share on other sites More sharing options...
timj Posted November 2, 2018 Author Share Posted November 2, 2018 Thanks so much! Quote Link to comment Share on other sites More sharing options...
