Dynamically Create Curve Point Custom Handles
Hello guys,
Is there a way to create to dynamically create curve point custom handles ?
I know I can create a simple curve in HDA and export the curve handle to the HDA, but I can't animate the curve position and edit the curve after. The curve node doesn't take account of the transform node, so it's a bit wierd to modify the points of the curve when the result is 100 meters away.
Any help would be appreciated !
Edited by anthonyblanchettepotvin
