Global Timing!
Maya has a Global time node " time1" , It has a certain fps by default!
but i can animate time1 node with a animCurve to modify the Global
timing ! How can I do that in Houdini?
For example : I have Dop network/Pop network and some animated
sop objects in the sence . I want to repersent slow motion effects in
a certain range . How can I use a single "animCurve" to slow all of
them ?
can you help me ? :unsure:
Correction - Maya has no global time - everything is local there.
So you need a local non-linear time in Houdini ?
Take a look at the CHOP's located in CHOPs\Shape. You will figure it out.
The particle CHOP is broken, so be aware when working with POPs and CHOPs.
27555[/snapback]
YES. I mean that the simulation is connected to time1 by default in maya. so I define it as global time personally.
thank you ! I will try my best to figure it out .
