calibrix Posted December 3, 2018 Share Posted December 3, 2018 Hello, I'm working on a project and I'm a bit stuck on matrix transformation. I don't have a strong background in matrix manipulation. Here is what I am trying to do: I have a packed alembic that has been created from an external program. The alembic has a fullpackedtransform intrinsic that contains my translate, rotate, scale and shear data. I want to shatter this alembic geometry, pack the shatter pieces and use the original alembic transform to animate the pieces which will then be input into a rigid body simulation. I'm having trouble extracting the relevant data from the 4x4 matrix on the alembic. I can get my points to translate, but I don't yet understand how to make them rotate. I hope my diagram makes sense. Quote Link to comment Share on other sites More sharing options...
calibrix Posted December 4, 2018 Author Share Posted December 4, 2018 Ah ha. I've figured this one out. What wonderful late nights in the office can do. For posterity: To translate the pieces you can use a single point wrangle. You need you pieces (duh) as a input, the animated alembic and a rest alembic (probably the same frame that made the pieces). You extract the 4x4 transforms from anim and rest. Use cracktransform to extract translate, rotate and scale. Offset you piece position by rest translate. Subtract animated rotation from rest rotation, so that your starting rotation is zero. Use the maketransform command with your animated translate, offset rotation and in my case I wanted to ignore scale so that was set to {1,1,1}. You can set position to your offset position * you new matrix. For each piece rotation you set the "transform" intrinsic to the matrix3 of your new matrix. // current position vector old_pos = @P; // get packed transform matrices matrix anim = primintrinsic(1, 'packedfulltransform', 0); matrix rest = primintrinsic(2, 'packedfulltransform', 0); // extract transforms vector anim_t, anim_r, anim_s, rest_t, rest_r, rest_s; cracktransform(0, 0, {0,0,0}, anim, anim_t, anim_r, anim_s); cracktransform(0, 0, {0,0,0}, rest, rest_t, rest_r, rest_s); // offset position vector pos = old_pos - rest_t; // offest rotation vector r = anim_r - rest_r; // create new transform assuming scale matrix m = maketransform(0, 0, anim_t, r, {1,1,1}); @P = pos * m; // create new rotation matrix matrix3 rm = set(m); setprimintrinsic(0, 'transform', @ptnum, rm, 'set'); 1 Quote Link to comment Share on other sites More sharing options...
