Jumps in opacity / density of volumes at rendertime
Hi All,
I am rendering a simulation of smoke and it seems I got some "flickering" or "jumps" in the opacity values of my smoke.
It is obvious between frames 181 and 182, where the smoke dissipate a lot in some areas, then revert to previous values some frames later, between 184 and 185. And again between 188-189 and 189-190.
I am using the Pyroshader (without noise, without emission, only smoke, nothing fancy... no remapping of value, really straigth out of the bos shader). Nothing fancy neither in Mantra : volume limits up to 1, and opacity limit to 0.995, normal value).
Did this already happened to someone ? If yes, any thoughts on how overcome that problem ?
Edited by StepbyStepVFX
