danw Posted January 17, 2019 Share Posted January 17, 2019 (edited) I'm currently building "baby's first OpenCL kernel", to try and speed up setting border voxels in a field to a constant value. Plenty familiar with vex and such, but first time poking around with OpenCL code. I've got it working, except that I can't work out how best to pass in the resolution of the DOPs field I'm operating on. I thought that the stride_x variables might be it... but I've worked out I can only derive x and y resolution from them (dividing stride_z by stride_y), but not z res. I can calculate it using "Include Size" and "Include Voxel Size" - but it seems odd to be doing floating-point maths to work back to such a basic bit of info, and I don't know how much that'd slow down an OpenCL kernel. Is there any way to just pass the info straight in? (Edit: should probably chuck up the code I've gotten so far, in case anyone spots any other glaring mistakes while I'm at it :-P) kernel void windsandwich( int stride_x, int stride_y, int stride_z, int stride_offset, global float *vel_x, global float *vel_y, global float *vel_z ) { size_t x = get_global_id(0); size_t y = get_global_id(1); size_t z = get_global_id(2); size_t idx = stride_offset + x * stride_x + y * stride_y + z * stride_z; float3 v = 0; if (z<4) { v = (float3)(0.0f, 0.0f, 0.125f); } else if (z>( /*x_res_attribute*/ -5)) { v = (float3)(0.0f, 0.0f, -0.125f); } else { v = (float3)(vel_x[idx], vel_y[idx], vel_z[idx]); } vel_x[idx] = v.x; vel_y[idx] = v.y; vel_z[idx] = v.z; } Edited January 17, 2019 by danw Quote Link to comment Share on other sites More sharing options...
danw Posted January 17, 2019 Author Share Posted January 17, 2019 Found it. Needed to use the get_global_size() function. size_t x_res = get_global_size(0); size_t y_res = get_global_size(1); size_t z_res = get_global_size(2); Quote Link to comment Share on other sites More sharing options...
