hou.pwd().geometry() gives an error
haikalle
hou.pwd() refers to the node that's currently being processed, such as when a callback script is running in an HDA. you don't currently have a SOP node that you're running the code on at all.
first create a SOP network, then a node, then you can refer to its geometry(). for example:
myNode = hou.node("/obj/geo1/box1")
myNode.geometry()
