Object not created at correct location [solved]
evanrudefx
Hello!
would someone mind looking at my scene? I am trying to do an effect where an object splits into two objects, then the new one splits into two and so on. Its similar to recursive box split that farmfield did, except my new boxes are not getting smaller. Any way, I have a wrangle that creates a new point once the age gets past a certain number. In my wrangle I am setting the location of the new point to match the existing point.  As you can see in the photo it is being created above the point instead of the same location. What am I doing wrong? Actually in the addpoint I can set any value like {3,0,3} and it still wont go there either.
Thanks.
dice_dup.003.hiplc
Edited by ejr32123
