evanrudefx Posted February 2, 2019 Share Posted February 2, 2019 (edited) Hello! would someone mind looking at my scene? I am trying to do an effect where an object splits into two objects, then the new one splits into two and so on. Its similar to recursive box split that farmfield did, except my new boxes are not getting smaller. Any way, I have a wrangle that creates a new point once the age gets past a certain number. In my wrangle I am setting the location of the new point to match the existing point. As you can see in the photo it is being created above the point instead of the same location. What am I doing wrong? Actually in the addpoint I can set any value like {3,0,3} and it still wont go there either. Thanks. dice_dup.003.hiplcFetching info... Edited February 2, 2019 by ejr32123 Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted February 2, 2019 Author Share Posted February 2, 2019 I found the problem. Please no one look at the scene. Its because I accidentally copied a box with transform of + 7 in the Y. Stop looking at this thread, nothing to see here! Quote Link to comment Share on other sites More sharing options...
