Separating Reflections
Flamingburrit008
Hello,  I'm trying to change the color of an object in cops, but I keep running into a problem. When I change the color of my box object to red in cops, the color of its reflection remains white. I've tried messing with the indirect reflection image plane, but that changes the color of all of its reflections. What I want to do is change the color of just the box to red in cops while keeping the other reflections the same.
Basically from this:
To this:
This is what I  am currently getting
Any advice would be greatly appreciated. Thank you
reflect_test.hipncFetching info...
Edited by Flamingburrit008
render a mask for the box and its' reflection as a separate pass. that's the simplest approach i would choose. you could also do that in shader and have it as an aov, that would be more complicated on shader side of things thou.
