Azmisov Snow Simulation
ivr
Hello, everyone!
I have tried the implementation of snow done by Azmisov, found here: https://github.com/Azmisov/snow
In his falling_spheres.hipnc example, I looked at his multisolver which has a long list of parameters in the interface. Inside the solver there are a lot of nodes (including an empty object) which once you middle click on them, they display the number of particles (defined as a parameter of the multisolver) and the attributes of the particles (density, position etc.).
There are no obvious connections or paths specified and I couldn't figure out from his code either how he managed to send that information around. I attached a photo to better explain what I am confused about.
Thank you!
