nibbla Posted April 10, 2019 Share Posted April 10, 2019 (edited) Hello! I've got a series of duplicated objects that I copy to some points, and need each output object in its own separate group. I've experimented with having the copy to point node in a foreach loop and then nest another foreach loop where I rename the groups from the copy to point node inside that one. Example file attached. All help is greatly appreciated!!! Best, Nibbla copy to point separate groups.hipnc Edited April 10, 2019 by nibbla 1 Quote Link to comment Share on other sites More sharing options...
nibbla Posted April 10, 2019 Author Share Posted April 10, 2019 I just solved it. All I had to do was to put the iteration number in the group output of the copy to point SOP! 1 Quote Link to comment Share on other sites More sharing options...
