parm template invisible toggle with python
celd
is there a way to set the "Invisible" toggle on a parm in Parameter Interface with python? All I could find was .hide() function which indeed hides the parameter but if the parameter is horizontally joined with a string parm, it leaves an empty space instead of having the string parm completely fill out the row. It acts the same way as the "Hide When" conditional.
So I want to be able to do the same thing as when I open parameter interface and toggle "Invisible" - in python.
Thanks
Edited by celd
