Cloth penetration problem
Hello!
Having a problem here in which I can't figure out for the life of me. Houdini cloth is being so picky about this unless
I'm approaching this the wrong way. If you open the file, you will see some objects: sails and little ropes.
I need the sails to collide with the ropes, but the ropes keep penetrating the cloth (cam 2) when I do a pre-run of 48 frames.
Can someone please help me get this right and correct the setup if needed in order to get a good collision and deformation?
Thanks!
geo.rar
sailropeclothtest001.hip
Edited by Syrena
replace files
1 hour ago, celd said:
You havent provided the source geometry so people cannot really help you. I would however suggest you use vellum for this, instead of the old cloth solver, it was never very good.
I reuploaded the working file plus the geometry.
