RickWork Posted June 20, 2006 Share Posted June 20, 2006 Hello, I'm trying to understand how to use the Switch SHOPs as well as Shader SOP for different renderers. I'm pretty lost here. For the Switch SHOP, I can have different shaders wired in and based on the renderpass variable it will choose the right one? So I take it I have to have a pre-render script to setenv RENDERPASS a value correct? Is this the practical workflow? Taking this a bit further, the Shader SOP has an option for renderers. I tried setting a vex super material for Mantra, and vex constant for OpenGL. I did this all in 1 shader sop. As you can guess this doesn't work. So I appended another Shader SOP to the chain. Shader Sop1 has the renderer set to mantra with a vex super material (yellow color). Shader Sop2 has the renderer set to opengl with a vex constant (blue color) material. If I render with mantra I see the vex super material. If I render with the opengl rop, I see the vex super material? So in this case, I think my workflow is wrong.... Any clarification you could offer would be appreciated. I attached a simple hip file with my setup in regards to the Shader Sop. Cheers ShaderSOP_aa.hip.gz Quote Link to comment Share on other sites More sharing options...
