Kaprolactam Posted May 7, 2019 Share Posted May 7, 2019 Hi everyone, I've got a problem that has me stumped. In my setup, I'm flying with a camera through a volume that has its density modulated via a couple of noises in the mat context. But whatever I do, I'm unable to make the noises stick to their position, it seems like the P attribute from the globals node is always in camera space. I must be missing something obvious since a lengthy internet search didn't give me any meaningful results. I've attached my file, to observe the problem just render a frame and then jump to another frame, the camera will have moved but the noise pattern is in exactly the same place. Thanks in advance Paul world_space_noise.hip Quote Link to comment Share on other sites More sharing options...
Kaprolactam Posted May 7, 2019 Author Share Posted May 7, 2019 (edited) Oh joy of joys, I found the solution, as usual, right after posting the question, and it is indeed rather obvious. A Transform (matrix) node (the one with the red icon) with its default settings does exactly what I need, i.e transforming the current space to object or world space and the noise stays in place. Edited May 7, 2019 by Kaprolactam Quote Link to comment Share on other sites More sharing options...
