Houdini Engine to Unity Scatter-HDA
OliverStock
Hello,
I tried to create a rather simple scatter tool for Unity to test a few things. Most things work but I have a few questions.
1) Since I am importing all my scatter-objects in one object merge node differentiating between them is not easy. I worked thorugh this by checking connectivity but I feel like this is not the intended way.
2) I want to weight the scattering and added a couple of float-parameters to the hda (weight1, weight2, ...). I have not found a way to hide the parameters when they are not needed though. I added an int-parameter that checks "numobj" in the object merge node and tried to use this value as a way of hiding my weight-parameters but it did not work.
Example:
int-parameter foo = ch("merge_scatter_objects/numobj")
weight5 -> hide when { foo  <=  5}
When I made foo invisible I had no way to check the value of it in Unity, when I made it visible it was only driven by the slider next to it. Any idea what I did wrong?
3) The object merge node allows me to group the points, but having an integer with values from 0 to n would be much easier to handle. Is there a way to convert groups with a syntax of group_0, group_1, group_2, ... to an int "group" with values 0, 1, 2, ...? The way it is right now I have to cut strings and do other really slow and inefficient operations.
I also have not watched the 4 hourse of Jeff Wagner talking about HDA buiilding/HDA in Engine so maybe my questions get answered there...
HDA and .hip-File attached:
Scatterer_hda.hdanc
Scatterer_hip.hipnc
