johnLIC Posted June 21, 2019 Share Posted June 21, 2019 Does anyone know the hython command to run a TOP Network node? >>> hou.node("/obj/topnet__wedges").cook() I tried the line above in a Houdini Python shell. It did not error, but it did not do anything. Quote Link to comment Share on other sites More sharing options...
Outlawed Posted September 11, 2019 Share Posted September 11, 2019 Is there a button on the node to execute the operation? You might need something like pressButton() For example, if I was executing a ROP to press the 'Render to Disk' button: hou.parm('/out/mantra/execute').pressButton() I don't have Hou 17 in front of me to test Quote Link to comment Share on other sites More sharing options...
hyposecant Posted January 21 Share Posted January 21 import hou, os hou.node("/obj/top_network").cookOutputWorkItems() os.system("pause") Because TOPs is run on a different process the python script would exit straight away so I had to add a pause at the end of the script. Quote Link to comment Share on other sites More sharing options...
