Big array segmentation fault
ivr
Hello, everyone!
I'm trying to calculate some internal forces of some particles using information from 125 neighbouring voxels around each particle. For accessing those voxels, I'm using this array as a shifting index:
vector sha[] = array ({ −2 , −2, −2}, {−2, −2, −1}, {−2, −2, 0} , {−2, −2, 1} ,
{−2, −2, 2} , {−2, −1, −2}, {−2, −1, −1}, {−2, −1, 0} , {−2, −1, 1} , {−2,
−1, 2} , {−2, 0 , −2}, {−2, 0 , −1}, {−2, 0 , 0} , {−2, 0 , 1} , {−2, 0 , 2} , {−2,
1 , −2}, {−2, 1 , −1}, {−2, 1 , 0} , {−2, 1 , 1} , {−2, 1 , 2} , {−2, 2 , −2},
{−2, 2 , −1}, {−2, 2 , 0} , {−2, 2 , 1} , {−2, 2 , 2} , {−1, −2, −2}, {−1, −2,
−1}, {−1, −2, 0} , {−1, −2, 1} , {−1, −2, 2} , {−1, −1, −2}, {−1, −1, −1},
{−1, −1, 0} , {−1, −1, 1} , {−1, −1, 2} , {−1, 0 , −2}, {−1, 0 , −1}, {−1, 0 ,
0} , {−1, 0 , 1} , {−1, 0 , 2} , {−1, 1 , −2}, {−1, 1 , −1}, {−1, 1 , 0} , {−1, 1 ,
1} , {−1, 1 , 2} , {−1, 2 , −2}, {−1, 2 , −1}, {−1, 2 , 0} , {−1, 2 , 1} , {−1, 2 ,
2} , {0 , −2, −2}, {0 , −2, −1}, {0 , −2, 0} , {0 , −2, 1} , {0 , −2, 2} , {0 , −1,
−2}, {0 , −1, −1}, {0 , −1, 0} , {0 , −1, 1} , {0 , −1, 2} , {0 , 0 , −2}, {0 , 0 ,
−1}, {0 , 0 , 0} , {0 , 0 , 1} , {0 , 0 , 2} , {0 , 1 , −2}, {0 , 1 , −1}, {0 , 1 , 0} ,
{0 , 1 , 1} , {0 , 1 , 2} , {0 , 2 , −2}, {0 , 2 , −1}, {0 , 2 , 0} , {0 , 2 , 1} , {0 , 2 ,
2} , {1 , −2, −2}, {1 , −2, −1}, {1 , −2, 0} , {1 , −2, 1} , {1 , −2, 2} , {1 , −1,
−2}, {1 , −1, −1}, {1 , −1, 0} , {1 , −1, 1} , {1 , −1, 2} , {1 , 0 , −2}, {1 , 0 ,
−1}, {1 , 0 , 0} , {1 , 0 , 1} , {1 , 0 , 2} , {1 , 1 , −2}, {1 , 1 , −1}, {1 , 1 , 0} ,
{1 , 1 , 1} , {1 , 1 , 2} , {1 , 2 , −2}, {1 , 2 , −1}, {1 , 2 , 0} , {1 , 2 , 1} , {1 , 2 ,
2} , {2 , −2, −2}, {2 , −2, −1}, {2 , −2, 0} , {2 , −2, 1} , {2 , −2, 2} , {2 , −1,
−2}, {2 , −1, −1}, {2 , −1, 0} , {2 , −1, 1} , {2 , −1, 2} , {2 , 0 , −2}, {2 , 0 ,
−1}, {2 , 0 , 0} , {2 , 0 , 1} , {2 , 0 , 2} , {2 , 1 , −2}, {2 , 1 , −1}, {2 , 1 , 0} ,
{2 , 1 , 1} , {2 , 1 , 2} , {2 , 2 , −2}, {2 , 2 , −1}, {2 , 2 , 0} , {2 , 2 , 1} , {2 , 2 ,
2});
I isolated it in a separate attribute wrangle and this was indeed what was causing the Houdini crash. Does anyone have any advice on why Houdini crashes because of this array?
[SOLVED] the minus signs were dashes instead, the array was fine otherwise
Edited by ivr
SOLVED
