Pointers and struct children in vex
Lucy Coleclough
Hi there, I am trying to define the shape of lightning using vex in a wrangle sop
A lightning path has forks that split from any given path, creating other paths with almost identical properties to the main path. To that end I created a path struct but I can't figure out how to get it to store its 'forks'. The same issue would arise if I instead stored the parents instead of the children.
I am defining a path of lightning as so:
struct lPath
    lPoint source;
    lPoint sink;
    float energy;
    lPath forks[];
    void setSource(lPoint newSource)
        source=newSource;
    void setSink(lPoint newSink)
        sink=newSink;
    void setEnergy(float newEnergy)
        energy=newEnergy;
    void create()
        addprim(0,"polyline",source.num,sink.num);
my issue is that I can't include a reference to itself due to infinite recursion, which is why in c++ I would use a reference
lPath * forks[];
Is there any way to solve this using vex?
Kind Regards
George
