evanrudefx Posted September 20, 2019 Share Posted September 20, 2019 (edited) Hi, Question about about viewing vdbs in the viewport. If you have a vdb, and turn up the anti aliasing samples, it causes the vdb to appear "open" in the viewport and you see square patches. The higher the samples the worse it gets. This only affects the viewport, it I convert it back to polygons everything is fine. This doesn't seems to happen in 16.5. Is this intended fuctionality? Thanks Edited September 20, 2019 by ejr32123 Quote Link to comment Share on other sites More sharing options...
