Help With Fast Blur Shadow Using Zshadow
Hi there,
I've been trying to use the advice given in the Wiki about creating fast blur shadows by rendering zshadow and then using it as a SHOP shadow (http://www.odforce.net/wiki/index.php/FastBlurredShadows)
However (as usual) I am running into a few problems:
1. How do you control range of the zdepth? The generated zshadow fades out before I want it to.
2. When setting the z(depth map) shadow, there is an option for depth outside field of view -- can someone explain what this is and what to put in it?
I'm also getting what appears to be shadow banding in the zdepth map -- any ideas how to fix this?
TIA
Ziggx
