Import attribute VOP is not there in houdini 17
uttam
Hi guys i m new in Houdini  so i saw tutorial for tornado that guy using older version of  Houdini so in VOP he took import attribute node but in Houdini 16 &17  import attribute is not there . so what should i do.Even tried bind export but i didn't get that thing properly can anybody explain pls........
If it's a point attribute, you can use getattrib, this can import any type of attributes into your vop. There is a attribute class parameter you can change to import point/prim/vertex/detail attribs and even groups. Or there is another couple node can import individual attribute class, for example import_point_attribute, import_primtive_attribute, import_detal_attribute, import_detal_attribute, all lives in the TAB menu under Geometry.
