automated linked parameters with for each node
Saya
Hi odforce,
Im looking for a way to automate parameter linking with newly created parameters from a master node. At the moment I have created a single node with parameters which contains a folder type parameter. you can manually adjust how much new subfolders are created, this amount should be connected to a for each or some kind that copies the assets. New parameters from that new copied asset should now be connected to the ones created with the master node within the folder type parameters.
I have no clue if this is the right approach so hopefully someone can help me with this.
A picture and file example are attached.
Thanks in advance.
Automated linked parameters.hipnc
Edited by Marcomeeuwse
