Mazb Posted February 19, 2020 Share Posted February 19, 2020 Hi I was trying to do file cache from command line but i could not find anything about how to do it. Do you guys have any idea how to save to disk file cache from command line? Thanks Quote Link to comment Share on other sites More sharing options...
Mazb Posted February 19, 2020 Author Share Posted February 19, 2020 i got the solution for rendering cache but another problem is skiping frames. i have multiple machines so i can render on all machine but want to skip existing frames. I found some people using "if path exists do node.bypass(1) else do node.bypass(0)".but this doesn't seems to work. Do you guys have any idea? Quote Link to comment Share on other sites More sharing options...
