tagosaku Posted February 25, 2020 Share Posted February 25, 2020 hi, I have a question about SOP scalar field vs gas match field in DOP network. When I want to create a custom field, it seems that the both of SOP scalar/vector field node and gas match field node can create a new volume field. The both can be output and saved on SOP level, too. Maybe gasMatchField has less options to set property. Do we have any special situation to use a SOP scalar/vector field node in order to create extra fields? Quote Link to comment Share on other sites More sharing options...
